Here's how to access the parameters:
1. Turn off the control power, then turn it back on.
2. After the control boots up, turn on the parameter edit switch that's on the front of the control. This switch is right on the cnc computer itself and not on the machine control panel.
3. Press the 'P' key on the keyboard.
At this point you should get the parameter edit screen.
If you don't mind me being nosy, what is it you are trying to change? This is a punch control isn't it?
HTH,
Scott |
