Old 01-23-2006, 12:21 PM
max_imum2000 max_imum2000 is offline
max_imum2000 is on a distinguished road
here is a side view drawing
well the part should be as accurate as possible
and yes the radius is perp to the angle and it is all the way along the length
does these methods gives a smooth surface ?
also can i shape a cutter to the exact same dimenstion and cut it using a shaping machine ?
is so , then how can i shape the cutter that accurate ? i mean make a perfect half circule in the cutter ?
your help are much appricated
