If you contact Hardinge or EMI, they should be able to provide you with a copy of EZTRAK Ver 6 user manual in PDF - Hardinge sold me a copy about a year or so ago. I have it here someplace but it is BIG and chokes many mail servers when sent via e-mail.
They may make you buy V6 software but it is a bit buggy.
The Ver 6 manual contains the G code that the "TRAK recognizes. It does appear to be mostly a copy and paste of other G codes from other machines with some do's and dont's.
As long as you start out simple, you can get the code to work. Add features as you go and fix stuff that hangs/crashes the machind (do aircuts when debugging).
We have G code that cuts masters written from these tables. The code ports almost exactly into a HAAS with only subtle changes for tool R&R. |
