help with hsm on our RH19 | | I'm looking for help on High Speed End Milling of Hardened D2 Tool Steel.
I'm new to milling hardened steel.
Tool Selection I figure should be solid carbide with TiAIN coating or am I wrong on this? Also any input on rpm and feedrate would be very helpful.
I attached an image of the part I want to machine. There is .025-.030 in stock that needs to remove from the od. Approx 8.500 inches in Diameter and .750 thick.
Thanks for any help on this |
