Exactly, that was what I ment by setting limits to the size of the table. And with good programming you wouldn't have to reset them to the work.
Have you had a chance to luuk up vericut. It's designed to check your programming to make sure you don't hit clamps or amything by running your code as a graphic simulation. You can also check to see if the finished part in the simulation is what you really expect based on that you programmed in with your code so you don't waste and substrates or stock.
Steven |
