Within the limitations of bearings, clamping power, etc, try this trick. Make sure your collet and the collet seat area is clean,(use acetone) Go to an industrial supply house and get a small bottle of Dykem Blue Layout Dye. Coat the cutter shank and let it dry (Just a few minutes) then insert far enough so the entire collet has shank in it. Tighten the crap out of it and take LIGHT cuts.
Mike |
