You could also create a plane parallel to the end of the angle offset the distance to the hole. Then project the outer 90 degree edges of the angle to that plane. Add a line at 45 degrees to form the triangular chamfer shape and then trim the projected lines to it. Then extrude-cut the sketch midplane to the desired length.
There are many ways to achieve the same result. Stick with what works for you. |
