Issue w/ Boss9 Post - Contour Cuts | | Greetings,
I have a BridgePort Discovery 308 w/ the SX15 controller. I am using a slightly modified Boss9 post processor and still have one issue. When using "deep cuts" for a contour cut I get a G0, rapid move, of the Z axis when the next depth of the cut is to be started. At present I go through the NC file and edit it, changing the G0 to G1, feed rate move. It seems that this is a problem only when a "lead in/ lead out" feature is NOT used.
I have not been able to figure out how this can be fixed in the post, or if it can be fixed. Any ideas?
Thanks,
Kevin |
