Old 01-13-2006, 06:12 PM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is online now
It sounds like the problem is in the drive. Is your incomming supply OK?
Check the motor over, brushes etc, and do a resitance check of the field and check for loose connections etc.
The field voltage should be constant, some drives have what is called field weakening, the field voltage is reduced to attain high rpm, this only occurs after a certain high rpm.
