Both, but hopefully not at the same time. The spindle (quill) typically has about 5" travel. And the head can be raised and lowered by a larger amount (which depends on the exact model). Typically there are two nuts that must be loosened before raising or lowering the head (and then retightened) and a single lever for locking or loosening the quill.
Alan
Originally Posted by gloogan So the round column is more like a drill press I take it. The spindle moves up and down correct. Or does the whole head move up and down? The only thing is I'm limited to 110v unless I run a new line to my garage. I dont really want to do that so thats really my only limitation, other than getting a full sized bridgeport but those are 3 phaze any way.
I just want to thank everyone for their input and opinions again, I'm glad I found this site.
Thanks, Jake |
