Old 01-07-2006, 11:02 PM
miljnor's Avatar
miljnor miljnor is offline
S.N.A.F.U.
miljnor is on a distinguished road
will probably forget alot. (some of this might have been address I only have up to whatever number was last years version)
Well here it goes:
1. Tool libraries. How much of a pain is it to redo tools in most programs! Just beeing able to copy them from one prog to the other would be nice.
2. Get rid of or set to off as the starting state for the little red Axis changing thingy. So anoying to accidentaly hit that thing.
3. make it so that you have to point at the actuall number of the dimension line to select it. (don't know how many times Ive had to turn the dimensions off jut to be able to select a line.
4. Heres on that no one has done yet. make it so you can round a solid model edge as if a corner rounder was doing the rounding, instead of blending the whole dang thing (or worse yet giving you an error that the blend is too large, especialy when you know that a cutter could easily make it)
5. make someway to move between the tiles faster than the current way. (if you have 30+ tiles it just takes to long to get to the top)
6. tool library..... did i say that already?
7. make the cut reander so it just gives you a final so you don't have to watch the tool (a button or something, becuase after about 10-20 times it get real old)
8. better 3d cut paths (i still have to mess with these way too much to keep gouging and run over from kill me)
9. changing the light source direction on the rendering would be nice. although I can make do with what is there. (so hard to make out stuff if you don't have the part tilted the right way, and when you change the direction it has to go through its cut paths again.)
10. did I mention tool libraries?????
Thats all I could think of. but Im sure I will come up with more.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
