Old 01-03-2006, 08:39 AM
DareBee's Avatar
DareBee DareBee is offline
Monkeywrench Technician
DareBee is on a distinguished road
You will need to create a point at an offset distance equal to the radius of your drill. This point will have to be created at each oval, then select these points as the machining region in your drilling MOP.
Also; it may be easiest to create the points by using "2 point circle" creation and then use the centerpoint, this will give you the same results without needing a calculator.
www.integratedmechanical.ca
