The gecko needs the second channel to know which way the motor is turning. The channels lead/lag each other. If channel a is lagging b, it may be clockwise, and if b is lagging a, counterclockwise, for example (this varies from setup to setup, and sometimes you need to switch the a and b channel inputs on the geckodrive to make it work).
Eric
__________________ I wish it wouldn't crash. |
