  #12   Ban this user!
Old 12-26-2005, 07:43 PM
Geof Geof is online now
Originally Posted by Kevin Taylor
You could make a simple die out of hot roled plate stacked together to make the offset with a couple of pin's to line up the two halves and the plate tap the holes afterword's I think the machinest guide or a pressbrake manufacture can calculate the tons needed your shop press should do it .
Yes, I dug out one I had made a few months ago and was going to take photographs.
Energystuff: Do you want to see it?
Based on my experience doing all four bends in the same die may need something like 80 to 100 tons. I was doing a similar but smaller offset bend in 1-1/2 by 3/16 cold rolled bar and needed around 30 tons. The bottom line is that it would be possible to build something up to bend some samples if a big enough press is available. For large scale production you go to the experts and get a proper die made.
