Samualt,
I wouldn't get too distracted by the big numbers of max peak torque and peak current. Those are design limit parameters, not optimum running conditions.
The motors will stand 9 amps continuous at 60 volts, so that is what you need, plus a little reserve. If the power supply has a capacitor or two, it may give you the capacity for the peak surges, which are only momentary conditions.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
