1946 Bridgeport M Head Retro WriteUp | | Here is my almost finished CNC retro. The machine is a M head BP. It is three phase and old. The ways and lead screws are in ok shape, at least good enought for the things I make.
Computer:
P3 800Mhz with 128MB RAM, 10gig HD, AGP Video Card.
Runing Mach3 at 35Khz
CNC Controller Box:
3 Centent 10uS Drives on big heat sink at 5amps
Transformer 220V to 47V
Capacitor 41,000 uF
Diode bridge
Circuit braker
Fuse for each drive
Screw terminal bar
CNC4PC breack out board
5V supply from game port
Line filter
Fan
Motors:
Zebotronics 720oz, 200 step
Drive 2:1 #25 chain
The motor mounts are flexible a little to keep the chian tight. The X motor has a adjustment screw in the middle of the plate. I know this is not the best way to drive a machine but I had the sprokets sitting around useless. I can not measure any backlash in the chains. The screws have a little backlash the X has .004 and Y .007 the table movement .0009.
The motors will move the table up to 60IPM and will cut 1/2 aluminum plate with a 3/8 end mill to 45IPM.
The limit switches need to get connected and a E-Stop button. Also a pointing device for the monitor is needed, I'll try to get a light pen for that.
I still need to make covers for the chains and handles. You can see I made one in the picture. I don't have the Z done yet as this is the more involved axis. But working on a few ideas.
I am very happy at how it is perfoming!
I hope this thread will encourage and/or help some one with a BP retro. It is worth every penny and minute spent!!
__________________ Dennis |
