Those were probably bent on a 35 to 50 ton press brake in a die. Doing it that way would be the easiest and most accurate. You would want to keep the bends equal and plate parallel.
__________________ If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down. |
