Thread: Amilam 3300MK
Old 09-18-2003, 06:31 PM
Durby Durby is offline
Durby is on a distinguished road
The first VMC that i programmed was a milltronics Patner IV or V so i remember alot of the glitches it had in the can cylces so i tried to avoid using can cycles and do it all in simple line moves but what baffled me was it had already done in same move in several sections of the part. I worked around it by doin an arc into the slug at that move and it seemed to work ok but the problem originated with an X axis fault that did not display. I figured that part out running some different programs. The Tool distributer is on his way tomorrow to repair it but he thinks it is a loose connection from the shipping. Thank you guys very much for your input and concern. Now I know I came to the right place.
Thanks again
