You can go to Lowes.com and enter: hitachi router
And this is one of them:
Hitachi
Variable Speed Fixed Base Router
Item #: 118359 Model: M12VC
$114.00
I liked that once I took the base off, it looked like it would be easy to mount also.
More specs from the site:
Powerful 11 Amp, 2-1/4 HP motor to cut through tough hardwoods
2-stage motor release clamp for accurate depth adjustments and base changes
Electronic speed control maintains constant RPMs even as load varies
Nickel plated motor housing for smooth depth adjustments
• See Our Rebates
Horsepower: 2-1/4
Amps: 11
No-Load Speed (RPM): 8,000 - 24,000
Depth Capability: 2.6"
Type: Fixed
Max Collet Capacity: 1/2" and 1/4"
Weight: 7.3 lbs. |
