Originally Posted by ger21 No need to sand them, they are really smooth. The flat is on one pipe, but not the other, and it's very small right now, maybe 1/16" wide. It might just be a softer area on that one pipe. |
Yea the Galv. Gas pipe does not need sanding, Ger21 maybe try to rotate that one pipe? if possible, Mine are not screwed in they are help by pressure and an end pocket the right radius of the pipe then torsion box screwed together.
Joe
