Old 12-18-2005, 08:40 PM
KEYTEEM KEYTEEM is offline
KEYTEEM is on a distinguished road
Question gear train/motor
hello again , i'm probably gonna drive you guys crazy for a while but i finally
have saved a few more bucks up and am gonna start working on getting my mill back together,and was wondering if anyone has taken the head
apart and cleaned up the gear train ,if so did you find anything needed in
paticular . i assume it doen't need to be done but i just don't know and
don't want to run it (at least a month away still) without some experienced
opinions.
also i have to remove the motor and removed all the bolts for it
but the motor just doesn't seem to want to lift off of it's base.
the motor case itself spins freely around and i evenly tried applying pressure
under it as i pull up but it seems like too much force is needed .
i really don't want to break anything! I don't see any way of getting to the shaft thru the case so i assume (hate this word) i am doing this correctly.
thanks for your help
