You are getting a following error. There is feedback in the parallel port driving code, EMC asks for a given velocity and the parallel port isn't able to keep up with it, so the position it reports back is outside the following error tolerance. I believe you need to drop the max velocity until you stop getting following errors. You are hitting the max capability of your computer. |
