As i'm sure you'll be able to tell, i'm new to LinuxEMC, recently got a Gecko G320 servo driver and was testing it out. Once it gets moving a certain speed the servo stops in its tracks and the interface says ESTOP. There is no feedback so I know it's the software stopping it for some reason, is there a MAX speed set somewhere that would do this?
It used to not do this, then I changed the max speed of the X axis (the servo i'm just playing with) upto like 40, just to see how fast I could get it turning. All my numbers are not setup in proportion to anything, so 40 means about nothing. Regardless after I did this once it gets going i'd estimate 200-300rpm it stops.
I guess I just need to read up on the emc config file...
Thanks in advance,
Ross |
