Originally Posted by vladdy If you are thinking of cleaning up parts around finger size or smaller, I like using a brass case cleaner, it uses an offset weight on a motor underneath, and the assmembly is spring supported, very little noise, and works well..
For aluminum or brass I usually use a corn cob type of media for a mirror finish.. for a satin finish walnut shell works well..
this is the one I use, about 22" high.. |
Well, if anyone knows anything about paintball, we're going to be annodizing paintball marker parts.
- So, bigger than bullet casings (maybe we could do SMALL parts in there)
But thanks for telling us that we'd do good with corncob for mirror finish
-Josh
