The motors have different size shafts. Thus the motor adjustable vari disc assembly and stationary varidisc assembly would be needed as well. Everything else stays the same.
BUT!
If you ever order parts for this head, you have to remember what you have done. Reason being that the drive to the back gear pinion shaft uses pulleys and a belt with round teeth on the 2 HP and square teeth on the 1.5HP. Typically a customer does not call in with part numbers and we ask what HP the head is and order parts by HP. You can see where this can lead to the wrong parts shipping.
George
