  #49
Old 12-07-2005, 08:33 PM
joecnc2006's Avatar
joecnc2006 joecnc2006 is offline
www.joescnc.com
joecnc2006 is on a distinguished road
I went to lowes and looked around but did not really see anything i wanted for motor mounts that would accept the 10-24 screws needed for the nema23 motors, so i descided to make my own it is very stout, cut them out then drilled and taped the ends for the screws to secure it from the bottom and also the motor to mount ontop, here is what i came up with (I will know when I get the machine up and running if the heat from the motors will have any effect on the HDPE but i think it will be ok).
Name:	motor mount walls.JPG‎
ID:	12639   Click image for larger version
Name:	motor mounted 1.JPG‎
ID:	12640   Click image for larger version
Name:	motor mounted 2.JPG‎
