Old 09-11-2003, 10:21 AM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Yes.
Find the circumference of your part. This might be a compromise on a lathe without constant surface speed, if the part has a wide variation in diameter.
For High speed steel tools, I think 800 feet (of circumferential distance) per minute is acceptable, and with carbide, well, I don't know of a practical limit where you won't chicken out before the spindle gets going that fast
The feedrate depends on the tool radius and chipbreak, as well as the desired finish: .010 to .020" for roughing, .005 for finishing. Its quite forgiving really, the most compromising on parameters is done to try to get good chip flow for the insert you're using.
