Old 04-09-2003, 11:55 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Machining down to a defined level
HU,
In your post on milling down to certian level, you are working to HARD.
There is no need to add extra surfaces.
All you need to do is when you get to the section in the tool wizard that ask for automatic extents options is to uncheck the automatic z offset. This will ungrey the z offset option boxes. Then you can enter the depth that want to be z bottom of job and OneCNC will only mill down to that level.
