Originally Posted by anoel It's very concieveable if you have the means to mill and surface grind a new dovetail column or THK rail style column and a mating spacer for the spindle head. The fixed column extended Y base definitley has the extra capacity to handle a much bigger column than the X1 Comes with. If you do, the newly made column and Spindle could very well be done for no more cost than the X1 itself... |
I actaully have a 6X18 surface grinder.
Hmmm interesting thought there.
