Thread: Volume
Old 09-10-2003, 12:35 PM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
OIC, my bad..
This is done via .STL files in verify. You can either define your own shape, (fixturing, clamps, vises etc), and export it as an STL, or you can use the previously cut operation and save it as an STL. (There's really no need for the latter method, because you can verify all operations at once using custom WCS')
When defining your own stock shape, create a model of the fixture, then convert it to .stl. Then in Verify, open the options, on the top left there's a check box for FILE under Shape. Click it and select your stl file, bada boom, bada bing!
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
