Joe,
while you posting can you throw out some of the dimensions your using, like pipe spacing for the long y-axis runs. Any other dimensions would be great too. What would really be great if it wouldn't be to much trouble would be to post your drawings for the pieces as you build them like the gantry rib parts etc.
I'm thinking of trying to build the same type of machine as you go along. The main difference is that I'm looking at a 31 x x48 cutting area, and I'm going with plywood which I think would be a bit stronger in the long run.
Steven |
