Old 11-23-2005, 08:05 AM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
Well, on a long shot, maybe you need to change the resolution at which your video driver is running while in DOS mode. Typically, the program might assume that it is running full screen at 640 x 480 pixels, but perhaps your vga setting in the autoexec.bat or in the config.sys file (I don't remember which one holds this setting) is setting the monitor to run at a much higher resolution. Hence, it would appear to look like a small window.
What are the contents of those two system files right now?
Edit: another trick might be to change your screen resolution down to 640 x 480 while running windows. When the computer restarts on a warm reboot, the last used resolution in windows might 'stick' and carry over into DOS mode.
