Xeno
It sounds to me like you are having graphic interface problem !
1. Do you see the surface highlite after selection ?
2. Do you actually select surface, the surface may just be in query select you must right click to the surface you want when it is highlite then left click! left is you enter right is your query
query=( toggle through surfaces that are in range of graphic pick)
3.You Must have 3 button mouse for Pro E.
4.Pick deep hole for G83 cycle(must enter peck value in Parameter tree) . Pick break chip for G73 Your post Must be set up correctly in order for this to work.
5.Possible non compatable Vidio card
6. Has bugs go I have not had A bug in Pro E since I learned in Complete 99% of the time it is operator error
Please PM me and I can get you up and going fast I have training Material I can Send you
Mace |
