Originally Posted by BeanO I'm running a mazak integrex (1999) turning center,(4axis lathe,with milling)
I can get a Mazatrol main program to use an ISO subprogram, but I can't get a mazatrol MAIN program to run a mazatrol SUBprogram...
Any help would greatly appreciated...
...Thanks,
PS, I will post the correct controll soon...I think it's an integrex 35..??.. |
In the end of the main program make an "end" sequence
there you have 6 selections
"counter " "return" "WK No" " cont" "NUM" "shift"
punsh in the name for the sub program no under "WK No"
select 1 under the counter select 1 under return and 1 under cont
an do the same in your sub program only put in your Main program no under WK No
I hope this vil help you!
It works on an integrex 200sy with an 640Mt
