I should find out what style your machine is. Is your CNC like a standard vertical mill or does it have a moving gantry?
So when you press the 'Right Arrow' key which way does the table move or the gantry move?
If you have the axis setup correctly then I don't have an answer for you.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
