Originally Posted by phantomcow2 Well i have adjusted the fan so it aims more toward the LM chip, the chip is cooler. Still uncomfortable to touch but im hoping the heatsink I am making tommorow will solve, or at least help that |
How much higher is the unregulated supply voltage over the regulated, because the higher the excess voltage the more energy has to be dissipated by the regulator. A TO220 style case can sink about 25W when suitably cooled, so if you take the excess voltage being supplied to the regulator and multiply it by the current being drawn from it, you will get the wattage being dissipated by the regulator. Then you can work out the heatsink size required.
