Hi, all. Iam really new to all this and would like to offer a project for consideration.
Perhaps one of you would willing to use this for a tutorial.
A wedding ring, id 16mm, od 18mm, width 6mm. The top surface is curved from side to side, beginning .50mm from the id. The inner surface edges will be beveled 45deg beginning .4mm from the outer width. There will be 8- 1mm holes drilled through, spaced equally around the circumference.
Thank you so much.
Ken
