Thanks for all the replys and help!
You can see my products at
www.unabiker.com
I've got a drain in the bottom going to a 5 gallon bucket. I have a so-called pump from Harbor Freight, but it doesn't have enough poop to lift a 3/8" dia collum of water to the spray bar. Gotta get a bigger pump and it should work. My spray bar is a 1/4" copper tube, currently with the end plugged and 1 tiny hole drilled in it for the water to spray out of. I figure I'll drill some more holes after I see how the first works.
I'm assuming my motor is turning at 1740 rpm or there abouts. It's a single phase motor from a 5hp air compressor. The drive pulley is 3", the driven pulley is 5". That should give me about 1000 rpm at the axle.
The neighbors should be ok with the racket. They were going to put a metal stamping line in the unit next door to me. That being said, I like the idea of a big foam box to drop over it. I'm probably going to put in in my store room, just to add one more layer of sound deadening.
I like the filtering and evaporating idea for the goo disposal. As dry as my shop is, it should not take long at all to evaporate a few gallons of water. Especialy when the heat is on.
I hope to have some more time tomorrow to get it moved into the store room and bolted to the floor. I've got a ton of stuff I need to deburr.
Here are some pics:
