The G-rex can slow down. 2MHz is the max rate for most encoders and amps. With very good equipment you like to have a lot of bandwidth and the G-rex can do. If you have high end equipment you may need the extra bandwidth I can only say good things about the G-rex and I have had mine for over 1 month. Actually good is too mild GREAT fits this hardware better. My G-rex is handling a bunch of IO (input - output). The cost savings will be enormous for us on future machines. I am also working in the direction of from parasol id to the mill. In other words you load the SolidWorks model into the mills computer, answer some basic questions, set up tooling and offsets. Machine your part NO G CODE.... |
