Originally posted by Mortek How do most of you set up a chamfering tool? Since most have a flattened tip, how do you determine where Z zero is?
Then how do you measure them? I have a call for a .032-.035 45 degree chamfer on a 1.002-1.000 hole. I don't have a comparitor or a chamfer guage.
I have been setting the machine at an x distance from the center of the hole which I have determined for my tool path, Then I take chamfering tool down by hand and touch it off on the hole edge, set z-zero. But it is hard to see when you have touched off. |
I program for Z0 and manually set chamfers at the machine.
For your .032 to .035 chamfer how about setting it / checking it with gage pins.
jon
