Thats a nice system to index the bits that is cheap. I was looking for a piece I can screw into the threads of the Dremel, and connectors I can put on my bits - that link with a pin.
The whole point is to eliminate the need for me to unscrew the collet, put in a bit, and then screw the collect tight again.
I seen a quick-change system for sears router - simular to this same system I am looking for. And, for some reason I see systems like this for sale for too much money for what seems to me to be a simple few-part device that could be machined on a lathe; if I had one, or used one.
__________________ WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets. |
