Old 10-24-2005, 07:34 PM
mrbaseball mrbaseball is offline
mrbaseball is on a distinguished road
Originally Posted by Ursine
Here's what I did:
For the shaft coupling I had the 1/2-10 acme screw end turned down to 1/4 and used fuel line tubing. For the thrust bearing, I'm using Joe's idea of an adjustment block holding a 1/2 ID bearing with a acme nut on either side. This gives me plenty of adjustment for screw alignment.
Dave
How does that work in the first photo? I'm thinking that the nuts will also turn since the acme thread turned and it would want to pull the nuts toward the direction that the stepper motor is turning. Like the gantry is moved when the X axis stepper turns. Or am I missing something?? I apologize for being so thick headed
