Thread: New idea!
Old 08-26-2003, 10:40 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Smitty,
You just select the contor that you want to machine.
So select groove operation. Then as below you will see that if you select only the first groove,( from the start of the groove contor to the end of the groove contor), then go all the way thru the tool wizard it will write code for that groove only.
Then you can select the next groove. Then select your cut outs and so on.
