Old 10-22-2005, 10:13 AM
MetLHead's Avatar
MetLHead MetLHead is offline
Gold Member
MetLHead is on a distinguished road
Jason,
Try setting the machine configuration to Mill. Click the current configuration pane in the status bar and then click Mill on the menu that pops up. Some of the address values in the program do not have decimal points. The default settings assume a decimal place of .0001 units. The Mill setup has this setting at 1.0, so that values with no decimals are interpreted as whole numbers.
I did this, and while it drew correctly, I still got some arc errors. I will look into this and fix it for the next beta.
Regards,
Scott
