no, these are smaller pieces it woudn't cost that much if sent via USPS or maybe even UPS. Here are some photos of mvaughns machine for reference. The X axis I need four of these blocks, They are 1 1/2" deep (bearing surface) 2 1/2" wide and 3" tall. The other two axis I just need two each for each axis(see photos) two for the y axiz and 2 for the Z axis. The X axis is 1" diameter holes, Y axis is 3/4" holes and the Z axis is 1/2' Holes. They to replace the angle iron/skate bearing for use with the jgro router so that dimensions are the same as the parts there. I will upload a drawing later withe exact dimensions.
