Old 08-24-2003, 06:07 PM
Alan T. Alan T. is offline
Chip Sweeper
Alan T. is on a distinguished road
Smile Power Supply question
I am considering using the Xylotex driver board for a retrofit of a Dahlgren Engraver. My question is two-fold. One, the steppers currently on the machine are triple stack 23's, 3.4Vdc and 2.9amp.
Since the Xylotex boards are limited to 2.5 amps, will this cause me problems if I use these motors, ie: overheating, lost steps ect....
Second, am I reading correctly that the xylotex boards can use either regulated or unregulated power supplies as long as it does not exceed 35 Vdc? If I use a 24Vdc regulated supply that has 10amps capacity. Will I need to use anything to limit the current.
Thanks,
Alan
Pensacola Florida
