Thanks Balsaman:
For the info. Using solid state relays do you have to have a seperate circuit board to route the parallel port output signal to or can the SSR be ativated by pin 14,16 or17 being pulled low (to ground)? I have read a little about somethig called a "stamp" By Parrallax inc.
At this time we have the Xyotex board running fine , put all the components inside the computer atx case and it all looks great.
Has been a good 1st time project and Jeff Pollard has been a big help also, does he ever sleep?, he answers your email real quick! Art has be real good with software question about his Mach2 software . Highly recomend both. Thanks again! Cecil
__________________ cecil |
