  #11   Ban this user!
Old 10-13-2005, 05:06 PM
kong kong is offline
kong is on a distinguished road
Click on config at the top ok, then click on ports and pins.
There is a tab which says "motor outputs". In there, you will find the heading which says "Dir Low active". Changing the sign from an X to a tick or vice versa will swap the direction the motor turns when you command it to move.
My mistake for giving incorrect instructions last time!
