Here are some of them,will upload more later.
Read the G-code first to ensure you do not get any surprises. Some of them are different to others as I have not adjusted all the parameters. If the file has "fullprogram" as part of its name it will the code will indicate 5 plunges of 4.6 each, finishing at 23.0. The files values represent mm/min feed rates as well as mm units so make the relevant adjustments if you use inches.
You can use NC-Plot to check the toolpath. The demo gives 60 days of testing time.
Jason
Reason: error
