  #11   Ban this user!
Old 10-13-2005, 10:58 AM
wjbzone's Avatar
wjbzone wjbzone is offline
wjbzone is on a distinguished road
Here is a picture of the assembled box, I stained the wood so the joints would stand out.
I use turbocnc to run the router. The gcode came from my gcodeout.lsp program using Autocad.
All the joints were cut using a 3/8 bit with 0.005" clearance programmed in the gcode. I had to press the parts together. Other then my depths being slightly off because the boards were not planed, the joints are tight.
Also here is a drawing of a fixture to mount on my table to align the edge of the boards for the dovetail. Have not built this yet.
ID:	10934   Click image for larger version
